03-18-2020
01:07 PM
04:03 PM
James_C
After a few months of use the printer has begun making an awful ear piercing squeak when printing. I've troubleshooted as much as I can but am at a loss. I know the issue isn't with the toner cartridges and I've opened up the printer to see if there is any paper jammed and everything looks fine. Any solutions are strongly appreciated!
03-19-2020 01:01 PM
Hi Karlsev.
If you haven't yet done so, try cleaning the transfer belt.
As I expect you've already done that, and the problem persists, you'll need to contact our phone-based support for further assistance. If you're in the U.S., our support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
If you're located outside of the U.S., you may find your local branch of Canon using the Canon Global website: http://global.canon/en/support/
03-19-2020 01:01 PM
Hi Karlsev.
08-12-2024 11:48 AM
Just tried this and the noise disappeared. Very easy to do. Thanks!
