12-09-2024
06:14 PM
08:48 AM
James_C
After every *successful" fax my screen says "Suspended. Job in Progress." This screen will not go away, even though the faces are being received. Any help appreciated!
09-24-2025 11:38 AM
Hello,
If the message is coming up after sending a fax, it will usually mean that printing a tx report has been suspended. This can happen if the incorrect paper size is loaded or if the printer is low on toner. You can try replacing any empty/low toner cartridges and checking the paper size to make sure it is set to letter or A4.
