imageCLASS MF644Cdw Scan to Email Setup Help
Melissa-M
Can someone please walk me through setting up the scan to email function using both the remote ui and from the printer touch pad. I don’t understand port and smpt numbers and things and don’t know where to find them. I use spectrum wi fi and have a charter email address and a gmail address.
please, I need help!
1 REPLY 1
Are you using the printer with windows or MAC OS?
Since you are not familiar with scan to email set up and configuration, I would suggest using the send function settings tool to assist you with its configuration.
**The tool is only available for windows OS
Visit the support portal for your printer.
https://www.usa.canon.com/shop/p/color-imageclass-mf644cdw?color=White&type=New
Look for the tool mentioned above.  Select support, software/drivers and your operating system.  *Again the tool is only available for windows.
Note: If you have a MAC, the configuration has to be done manually.
You can use Google search to find the recommended SMTP email settings for charter/spectrum.  This one include the email address, password, outgoing mail server, port and encryption requirements if applicable.
Friends and Family
