10-15-2024
04:51 PM
05:01 PM
Tiffany
I am struggling to get my imageCLASS MF455dw to scan to email. I have gotten error after error the most recent one being error #801
10-15-2024 05:00 PM
Welcome to the forum!
So that the Community can help you better, let us know which version of Windows or macOS you are using? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
10-15-2024 05:04 PM
I am using Windows 10
10-27-2024 04:53 PM - edited 10-27-2024 04:54 PM
Log into the web Remote UI, Settings/Registration, TX Settings, Email/I-Fax Settings, Edit, and enter your SMTP server information, including your email server, user name and password for authentication, and you may have to check the "Use TLS for SMTP TX." You should then be able to enter any email address to send to on the LCD panel.
10-27-2024 10:10 PM - edited 10-27-2024 10:19 PM
To send mail, you have to configure SMTP Tx settings in the remote UI.
Who are you using for relay?
You will need outgoing server name, username, password, port # and encryption type if used.
In my examples below, I am using gmail.
I am using port 587 for SMTP Tx
Example Gmail SMTP Settings
SMTP Server Address: smtp.gmail.com.
Use Authentication: yes.
Secure Connection: TLS/SSL based on your mail client/website SMTP plugin.
SMTP Username: your Gmail account (xxxx@gmail.com)
SMTP Password: your Gmail password. (App Password)
Gmail SMTP port: 465 (SSL) or 587 (TLS)
If you are using gmail or M365, you need to use an App password. The printer does not support modern authentication.
Then put your frequently used destinations in your address book... PC's Mac's and email addresses.
Then you can scan / send from the printer's LCD with 2-3 clicks. 😃
