imageCLASS MF264dw II Error e805-0001
bkolacz
I get error after printer one page I get this error e805-0001 and it says to power off . Power off does not help. I don't see this code in the manual any idea on a cause or fix. Thanks.
4 REPLIES 4
dexman335
Mentor
Mentor
I Googled the failure code and it came up with a link that discusses the code associated with another printer.
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR1730&code=E805-0001
If the code is used the same way for both printers, it points to a failure with a cooling fan.
Greetings ,
I saw the same article this morning.  I'm not familiar with the 264, and am not sure it has a fan?
 it looks like it does on the right side panel. 🙂
Hector
Hello,
The code would pint to a problem with the hardware and it would usually mean the printer needs service. If you are getting a e805-0001 error, I suggest contacting support over the phone at 1-800-652-2666 or checking your service options by logging into your MyCanon account.
Friends and Family
