imageCLASS MF249dw can't print from iPhone 15 after iOS 18 update
jokewilkins
After updating my iPhone 15 to iOS 18.1, when I select Canon MF240 on my iPhone, I get "No Printer Selected."  I can still print from my iPad, which runs on an older iOS version.  I downloaded the firmware dated June 2024 and that didn't help.  Thanks.
5 REPLIES 5
Stephen
Moderator
Moderator
Hello!
So that the community can provide you with the best answer, please verify the model, which is physically labeled on the top or front of the printer.
jokewilkins
Model-Imageclass MF249DW
jokewilkins
Is there a solution for Imageclass MF249DW?  Thanks.
Thanks for the info, jokewilkins!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
Hello,
If you are having problems with printing after the update, you can try downloading and installing our Canon Print Business app. If you already have the app installed, you can uninstall and reinstall to make sure you have the latest version. If you continue to have issues, I suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
