i-SENSYS MF443dw Unable to scan via direct Wi-Fi connection
tlfadmin
Hello.
There is little information about direct connection on the network. It seems that there should be no questions. But there are many difficulties during setup. First, you need to configure the IP address completely, including the gateway. Otherwise, the Wi-Fi network is not created. The IP address must be different from the IP address in the direct connection menu. But even after the access point started working and I managed to configure the printer, scanning still does not work. When selecting Scan from the device menu, the MFP does not see the computer. When starting scanning from the computer, error 255.0.0 appears. How to configure scanning when connecting a direct connection?
Windows 10 Pro operating system.
0 REPLIES 0
