07-23-2016 05:59 PM
keep getting error message : set paper again, set toner again
I have resent both and still get error message
07-24-2016 08:26 AM
Hi, kkass!
So that the Community can help you better, we will need to know exactly which Canon printer model you're using. That and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help you 24/7 at http://bit.ly/ContactCanon
Thanks and have a great day!
07-24-2016 01:51 PM
I have Image Class D 480
08-03-2016 04:29 PM - edited 08-03-2016 04:30 PM
Hi kkass.
I will be able to assist you.
This error indicates that there may be a very small piece of paper located under the paper sensor inside the machine.
Please follow the steps below to check for the paper:
If the error persists, I recommend that you call us at 1-800-OK-CANON (1-800-652-2666).
