06-30-2014 01:32 AM - edited 06-30-2014 01:33 AM
I installed the latest driver as instructed but the only way I can get the scan to work is to create a shortcut to the C:\Program Files (x86)\Canon\MF Toolbox Ver4.9\mftbox but the start key on the printer in scan mode just brings up an empty box.
Anyone know a fix for this?
ImageClass D420
07-02-2014 10:53 AM
Hi pbconsultant.
I will be glad to assist you.
I recommend setting the MF Toolbox as the default program in the scanner properties. Please follow the instructions below:
1. Please open the [Devices and Printers].
2. Right-click on the D400/420 Series and select [Scan Properties].
3. Click on the [Events] tab.
4. The prompt will appear. Select the MF Toolbox program under "Start this program".
5. Select [Apply] or [OK].
6. Perform a scan using the [Start] button.
I hope this information is helpful to you. Should the error persist, or you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
07-07-2014 08:53 PM
07-08-2014 01:57 PM - edited 07-08-2014 01:58 PM
Thank you for your reply, pbconsultant.
Based on the error you are experiencing, I recommend that you contact our live telephone technical support. I understand that the forum may be your preferred method of communication, however, the real-time feedback with the telephone representative will be more beneficial in this case. Please call 1-800-OK-CANON (1-800-652-2666).
