Reinserting Multi-purpose tray on imageCLASS mf665Cdw
bnesler
I realize this is a very basic question, but I am having difficulty reinserting the multi-purpose paper tray in my imageCLASS mf665Cdw tray. Can someone direct to a video or provide a brief explanation. Is the multi-purpose tray installed after the main tray is inserted? I have not been able to reinsert it after removing it when transporting the printer.
Many thanks to any who help a person totally unfamiliar with Canon printers.
Bob
Can you take a quick picture for us?  Once the paper drawer is aligned it should slide right in.  The multi-purpose tray should not interfere with this.
https://oip.manual.canon/USRMA-9960-zz-SSM-660-enUS/contents/devu-mcn-name_func-pdrawer.html#01016_h...
Multi-Purpose Tray - Canon - imageCLASS MF665Cdw / MF663Cdw / MF662Cdw - User's Guide (Product Manual) https://share.google/cZaNmJRiz2FXY1cZp
That being said. The paper drawer can be extended for legal size paper.  If the drawer is extended, it will not be fully recessed into the bottom of the printer when inserted. You might have noticed the printer comes with an extra plastic piece.  This is a dust cover for the area of the paper drawer that protrudes when legal size paper is loaded.  Hopefully this helps.
2 REPLIES 2
Thanks for the help. My issue was reinserting the multi-purpose tray which I was able to do on removing main tray, reinserting multi-purpose trand then replacing main tray.
