11-13-2025 06:20 PM
In my browser I type:
Browser displays error:
[ip] refused to connect
Both in Preferences and in Management is shows Remote UI is enabled, when I look from the touchscreen panel.
What could be the reason?
11-14-2025 03:08 PM
In order to access the remote UI, one of two things must be true:
1) The printer has no remote UI password but it has been turned on for less than 15 minutes
In this case, you should get a form to enter the remote access credentials
- or -
2) A remote access password has been set from the touch panel
Be careful: You probably should NOT set an administrator ID.
11-14-2025 03:08 PM
- or -
