New ImageCLASS MF656Cdw won't scan
macclelland
I just purchased a new Imageclass MF656Cdw color printer.  I did the normal install and it prints fine, however, I can't get it to scan to computer via Wifi.
I am using Windows 11 and I installed the latest Canon drivers.
When I click on Scan > Computer then select my computer, click the Scan button, it shows it "thinking" and trying to scan, but nothing happens.  The paper stays in the feeder and eventually I get a message that just says "An error occured".
What am I doing wrong? Did I do something wrong with the set-up? Is it a wifi issue?
6 REPLIES 6
Based on your description, it sounds like you're trying to scan using the ADF from the printer's LCD?
Does the copy function work?
Have you set a destination on your computer for the scans?
What drivers did you install?  Did you install the MF scan utility v1.21.0.2?
Does the copy function work? Yes
Have you set a destination on your computer for the scans? Yes
What drivers did you install?  [Windows 64bit] MF656Cdw/ MF654Cdw/ MF653Cdw/ MF652Cw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear) & [Windows 32bit & 64bit] MF Scan Utility Ver.1.21.0.2
Did you install the MF scan utility v1.21.0.2? Yes
I played with it a while and finally got it to work.
But now I have two new issues I can't figure out:
1) When I scan legal sized documents, it cuts off at 11" letter sized.  I can't find an option to scan legal sized documents.  Any help?
2) When scanning multiple pages, it downloads with separate image files for each page.  Is there a way to have it scan as multiple pages in a single file?
Thanks
Good work solving the issue.  I'm away from my desk.  I'll look at my settings in a little bit.  My multi-page scans save as one file.
I have the same issues with my imageCLASS MF656cdw with scanning.
Step 1: Yes
I have tried several times with install/uninstalling software and I keep this error when scanning.
Please let me know what I am doing wrong.
Thanks
Hi MacClelland,
Did you ever figure out the 11" cutt-off on a legal (14')  scan?
I have the same issue.
RobertKC
