MF750 printer: How to disable toner status pop up window
crapko
Please tell me how to stop the "toner status" pop up window from appearing with every print.  If is wildly different every time i print ranging from 20%-100%.
If i want to check the status,,  I will open it.
thank you,
4 REPLIES 4
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, please confirm which model printer. Is it the Color imageCLASS MF751Cdw or the i-SENSYS MF750.
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Grant1
I too am having the same issue with my MF750C (MF753Cdw). I have gone through the web admin portal but cannot seem to find the relevant setting. All users on my network are getting daily popup windows (sometimes multiple times a day) with the Toner Status Monitor window. Can you please advise how to turn this OFF. Thankyou.
You can uninstall Toner Status.  Personally, I don't install it.  You can see your toner status on the printer's LCD or by viewing levels in the Admin portal.  If by chance you ran the toner down, it would display a message.
I have the same issue but am looking for a different solution.  I don't usually look at the display -- I grab the paper out when it prints.  I use the app to check, and would appreciate useful notifications, but don't find this one useful.  Or at least there should be an acknowledge option.
I have the MF753CDW (since that was asked of the original poster), although it's an app issue, not a printer one.  I have had the printer for about 15 months on the original toner.  I bought 4 of the large cartridges shortly afterwards.  It took me 15 months to drop from 100% to 30% on the black; I would guess that it'll take at least 6 months to empty it.  Guessing "prepare" means order a new cartridge, but even if I didn't already have it and appreciated that alert to order a new one, there must be a way to acknowledge that I have it (or got it and then had it).
I do not want 6-9 more months of the app popping up but do want to be advised when it needs to be replaced.  So, is there any way to do this?
Barring that, is there a way to get such notification when I need to do something?  I am not going to throw out a cartridge with 6 months or more of use left just to get rid of the annoyance but would appreciate a real heads-up.  And yes, if I hadn't bought the cartridges early, I probably would have appreciated an early warning so I could possibly look for deals.
I'm guessing that if I stop the service from running, I can run the app manually and then stop it again, but I'd be likely to miss when it gets critical and then be stuck at a possibly unfortunate time when I need it now and can't print.
(Glad I bought it when I did; the base price seems much higher, and in the future, I don't expect to get the discount for buying 4, since the colors are all at 90%.  I want color occasionally but don't use it much.)
