MF644Cdw Scanning
dws2006
This may be a dumb question but I am perplexed. I want to scan a multi-page document from the feeder but on occassion need to feed the pages one at a time, not as a stack pre-loaded in feeder. How do I set the scanner to wait for each page that is manually fed into the feeder, click "scan next" and let me click "finished" when I'm truly done?  I can do this from the platen but not with the feeder. What it current does is as soon as it detects an empty feeder, it assumes I'm done and completes the job.
Thanks
1 REPLY 1
Darius
Whiz
Hi dws2006.
When scanning multiple pages one at a time, you'll want to use the scanning bed.  This should cause the scanning software to take one page at a time, and prompt you for the next.  If you're unable to scan this way (such as paper size being too long), then you may need to scan the pages individually and then combine them into a single PDF page afterwards.
