Search instead for
MF 451 - scan to computer not working.
asinghvi
The scan to computer always shows up an error. The scan to file is working.
Also how do I turn on two sided scans to file from the printer?
3 REPLIES 3
Moderator
Moderator
Hi, asinghvi!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
asinghvi
It was windows 10. The scan to computer is now working. However I still cannot enable 2 sided scan to computer.
Hello Asinghvi,
You can adjust the scanner settings for the MF451 using the MF scan utility that installs onto the computer along with the drivers. You will find the Utility in your list of installed programs under Canon Utilities. Once you open the scan utility, you can click the settings option in the lower right to access the settings. You can adjust the settings for the scan utility and the scan options that are on the operation panel using the information found at the link HERE.
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
