05-07-2019 07:29 AM
Lately prints have streaks and missing text. I have repeatedly cleaned the nozzles and done some deep cleans as well. All ink tanks are full and I have selected the correct paper and print quality. I tried the highest quality and I got a printout full of ink smears, so went back to regular quality. The printouts of the nozzle check pattern and the print alignments look perfect, yet when I print documents there are lots of streaks. I also noticed that when I scan pictures there are streaks in the image that results.
Is there anything I am missing to try to resolve this problem, or should I consider replacing this? The printer is less than 2 months old and has seen light usage.
05-08-2019 04:15 AM - last edited on 05-08-2019 08:37 AM by Porcha
Hi jwbrine,
I understand when printing documents you have streaks and missing text. You have performed several troubleshooting steps; however, the issue persists. The next step is to perform an encoder film cleaning. Click HERE for information on cleaning the encoder film. Please read the entire article before attempting this process.
05-18-2019 08:52 AM
The instructions do not work. I've tried multiple times. Initially it says to turn on the printer, open the front cover and then turn the printer off and back on. However, when the front cover is open, the On/Off button is not active, it does nothing.
I did examine what I can see of the timing strip, there does not appear to be any grease on it.
Any other ideas?
