11-20-2019 07:37 PM
Since updating the bios, My MB2160 has thrown up the B504 error, is there a fix for this, like does the bios of a printer have a memory battery. how can you clear the bios, the normal factory reset thru the screen isnt doing anything..
went out and purchased new cartridges, they are more than what the printer is worth
11-22-2019 07:44 AM
This error indicates an insufficient ink supply to the print head. Since this can cause an overheat condition, printing is disabled.
Common cause of this error: using non-Canon inks. Lack of use might also cause this problem if the ink delivery system becomes clogged.
I didn't see any downloads for FW on the product's support page. How did you come by the update?
Not much from Canon on the error B504
Did see this, but am not sure if it will help
11-22-2019 07:44 AM
11-22-2019 08:32 AM
11-23-2019 07:32 AM - edited 11-23-2019 07:34 AM
Thanks for clarifying. This function is built into the printer's websever and is another method of software delivery used by many manufacturers. My HP does the same. It's safest to perform upgrades like this over a wired connection. Meaning connection via ethernet or cable, not wirelessly as this can introduce a point of failure. This applies to any device motherboard, router, printer, camera, etc.So always use a wired connection regardless of the device type.
