01-21-2020 12:27 PM
I recently replaced the head on my out of warranty IPF760. Followed the procedure on the front panel as I have done in the past with my other IPF's. This time the printer did not go through the process of replenishing the inks as it normally does. I powered down then back up in service mode and successfully printed the head adjustment page. Powered down then back up in normal mode. This time it started replenishing inks but then gave an error 2F30. Now every time I power up it goes through that same procedure always resulting in error 2F30.
If I power up in service mode it behaves normally, test prints in service mode from the front panel are fine and test prints through the utility software are fine. However when I try to send a print job to the printer (still in service mode), it spools, then immediatly disappears from the que window on the pc, the printer never prints, never see the flashing data light. I do see the flashing data light when I initiate a test print from the Canon utility software but I suspect that is internally generated data.
I have updated the printer firmware after the problems began.
Windows 7 Dell laptop
The only thing I have recently done with the laptop is install a Canon TR4500 series.
Thinking that may have corrupted something I have uninstalled all print drivers and reinstalled from the original cd.
Any help would be appreciated.
01-21-2020 02:03 PM
I made a mistake in the above post.
The error it is giving is actually 2F13, always after attempting to replenish inks after power up.
Thanks
01-23-2020 12:45 PM
Hello.
For assistance with this error, we would have to advise that you contact our support group over the phone by calling 1-800-423-2366, Monday - Friday 8:00 a.m. - 8:00 p.m. ET (excluding holidays).
