11-23-2023 02:37 PM
Maybe someone has a potential solution...
I would like to have a "shortcut" (Application Library, e.g. Scan to Cloud, Scan to Mail, Scan to FTP) with removing empty pages.
It's possible if I do not use pre-defined shortcuts, but not if I use some of the Application Library options.
I want to:
- Having a shortcut for e.g. Scan to Onedrive, with PDF OCR, duplex scan and removing empty pages.
As the function exists without shortcut, it looks like a software limitation.
Other related feature requests:
- option to change the naming schema for the filename for such "shortcut" scans
- option to define a folder within e.g. onedrive/dropbox/... (Scan to cloud)
05-06-2026 03:28 PM
In short... I want this too (even more as it is 2026 now).
Untill last week I was doing Scan-Data-"Recall Last settings" all the time, untill I learned that I can make a shortcut, which just magically sends the scans to my network drive (for automatic OCR and AI content recognition renaming and sorting ;D). It can be even set to scan without asking questions - great !
BUT exactly as the _Nickname user says, the empty pages skipping works very well for manual scan, but for the on-button-scans this selector/option is missing. It would be a very useful function, as I like the i-SENSYS machine and I do a lot of documents scanning with it.
Thanks and looking forward to it !
BTW, I cannot type associated products in the field below - it is i-SENSYS MF752cdw.
