09-15-2020 04:58 PM
Good Afternoon,
This is my first post, If it's been covered somewhere else please let me know.
i purchaser used a canon mf741cdw, it looks to be brand new, never used, but their may be a reason for that.
everytime the unit turns on I get a "control condensation" message and it wants to vent for 2 hours, it has never printed for me and everytime I try and print it just displays the message again and tries to vent for another two hours.
the printer is in a low humidity, air condition environment and has been that way for over a week.
Is what do I need to do to fix this... please help!
09-16-2020 12:18 PM
Sounds like you pourchased someone's problem. I'd return it.
09-29-2020 01:09 PM
The MF741Cdw should not be installed near a window or AC/Heating vent. The environmental conditions recommended are:
Temperature: 50 °F to 86 °F (10 °C to 30 °C)
Humidity: 20 % to 80 % RH (no condensation)
Try moving the printer to another location in the office.
Is the Control Condensation feature ON?
When the temperature changes rapidly in the environment where the machine is installed, condensation occurs. Select <On> to remove dew condensation in the machine. When selecting <On>, specify whether to restrict jobs.
Select on the MF741Cdw operation panel: <Menu> <Adjustment/Maintenance> <Maintenance> <Control Condensation> <On> Check the message <OK> Select the item <Yes>
While condensation removal is being performed, printing may not be performed properly and blank paper may be output.
If you set to <On>, you need to keep the machine turned ON to maintain the effect of condensation removal.
If you continue to have difficulties, please contact our support group using the following link:
10-31-2021 02:26 PM
I am having the same issue with my MFC641C, however, the printer won't even go into the mode, so how am I supposed to get it to work?
