01-13-2026
05:26 PM
08:55 AM
Hopefully a simple question. What band does the MF753CDW connect to. 2.4, 5, or 6. Just wondering. TIA
01-13-2026 09:27 PM
Network specifications from the manual are at https://oip.manual.canon/USRMA-7178-zz-SSM-750-enUS/contents/devu-mcn-spec-nw.html. 802.11n (2.4 and 5 GHz dual-band) is supported, but 802.11ac (Wi-Fi 5) and 802.11ax (Wi-Fi 6) are not on that list.
01-14-2026 08:16 AM - edited 01-14-2026 08:22 AM
The MF753 CDW requires a 2.4 GHz wireless broadcast that supports WPA2 encryption. The printer will not connect to a 5, 6 or 7 GHz broadcast.
01-14-2026 01:04 PM
I know the presence of the 802.11n standard would appear to make this printer compatible with 5 GHz, it is not. The printer only has a 2.4 GHz radio.
01-14-2026 02:30 PM
I thought as much, just wanted to know. The new router doesn't tell you anything other than wired or wireless. The old arris had a list for everything. Told me what radio, Ip, protocol, channel, strength. The new ones are a joke. I works which is good enough!!
01-14-2026 03:23 PM - edited 01-14-2026 03:24 PM
Many thanks to Rick for the correction! My bad for assuming that the specs implied full implementation.
And super glad that it works! That's what really matters!
