Color imageCLASS MF656Cdw: Printing from the Remote UI
Mudaris
I wasn't sure if this was the correct location. I have a Canon MF566cdw
Anyhow, I want to know how to print from the remote UI -- is there a way to do it so that if I have say, a word doc or PDF I want to print, I can do it? The instructions Canon has whenever I look it up says either I need the Direct Print Kit, or they say I can click on a direct print option that doesn't appear in my remote UI.
I have no clue what the Direct Print Kit is, I google it and it just loops back to various mentions of it but it does not say whether I can download it or link to it. It's this mysterious thing.
This is what my remote UI Looks like, I am using a mac, I would like to know if I log in from a windows machine if IU can print from it. The reason I want to do this at all is that my wife's windows machine seems to not want to "talk" to the printer over our network; it appears on the list, but when we try to connect it comes back with "that didn't work" -- and we cannot install the driver on her machine because she is not an admin. And her security protocols prevent us from simply putting it on a usb stick.
Anyhow, any assistance is appreciated. I attached a screenshot of what my remote UI looks like, there is no direct print option on there. I did set up a pin and logging in works, at least on this browser.
Screen Shot 2024-08-08 at 4.49.52 PM.pngScreen Shot 2024-08-08 at 4.49.52 PM.png
2 ACCEPTED SOLUTIONS
The Remote UI is a convenience feature that allows you to configure features, settings and advanced functions of the printer.  It is not used for scanning or printing.  It's a web based settings editor.  There is no scanning or printing functionality built into this utility.
Printing from a remote computer.  The printer has a feature called iFAX.  It requires that printer has Internet connectivity.  This feature allows you to send an email to an address configured on the printer and supported attachments are printed when received.  It essentially works like a fax machine, but you don't need a phone line and instead of using a telephone number, you are sending to an email address.
This is a feature of the device that you program in the Remote UI.  The same way you'd specify paper type, a scan to destination (like a computer, email or cloud based application). Google Drive, one drive, Box, etc.
The settings for this are located on the same screen as Tx (Transmit Settings).  They are Rx (Receive settings).
I found the reference for the Direct Print "Kit" you must has stumbled on searching the web.  Yes, it's for another device (Image Runner).
"Direct Print" is already built in and included on your Image Class printer.
If you have other questions, please let me know.
You have made good progress.  Here are the settings I promised.
Configuration for iFAX.  I only use Send, but below I've highlighted how to Rx (receive)
Once the POP Rx box is checked the 3 fields above become editable.  You will need an incoming server address, username and password.  I do not use iFAX, so have not tested it.  I still have an analog phone line for my once a decade faxing needs.  I see no reason why it wouldn't work as long as the mail provider supports POP.
Below are images of how to enable POP in Gmail or Microsoft. 😃
Example Gmail:
Example Outlook
There are 2 more details I feel are important to point out.  You need to configure 2FA and use an App Password  for Google.  Using a mail account, or any account these days without a 2nd factor for authentication is asking for trouble.  This is required since the printer does not support modern authentication for inbound or outbound mail.
Note: When you enable pop or imap, both google and Microsoft provide the incoming mail server for you. 😉
*I'll have to repost the images.  I copied them from another one of my threads and they are hard to read.
12 REPLIES 12
Sounds like you have some challenges going on there.  I own the MF656Cdw as well.
Your printer needs paper 😃
I can help with install on PC or MAC, but the user does need to have local admin privileges to install the drivers and software.  It sounds like her PC is a corporate issued device and that she doesn't have local admin privileges, or the ability to save to USB.
A Direct Print Kit License is not supported on the MF656Cdw.  Where are you seeing that?  Its not in the Printer's User Guide.  I think you are chasing something that is not needed or does not exist for this model.
Canon - imageCLASS MF656Cdw / MF654Cdw / MF653Cdw / MF652Cw - User's Guide (Product Manual)
You can print directly from a USB Stick using the printers LCD.  You don't need to log into the Remote UI and you don't need anything special to do so.
Using a USB Memory Device - Canon - imageCLASS MF656Cdw / MF654Cdw / MF653Cdw / MF652Cw - User's Gui...
Once the drive is inserted, look for a menu option on the LCD called "Memory Media Print"
Once selected, the supported files types are displayed.  JPG, PDF, TIFF, Docx and others.  Tap the file and you can print.
Note, the manual says the USB stick must be formatted FAT16 or 32, but I just stuck an NTFS formatted drive in my 656 and had no problem browsing files or printing.
If you use your MAC to format a USB stick, make sure you select a supported file system.  I haven't tried HFS+ or APFS, so I suggest sticking with a supported file system.
If you want help installing on either system and have admin permissions, let me know  😊
Yea, I figured out how to print from a USB stick. Again, I am trying to suss out whether it is possible to PRINT FROM THE REMOTE UI. That is, can I or can I NOT use the Remote UI to print a document from a remote computer, as a work around?
I kept seeing references to direct kit print when I did google searches. It would take me to a manual that clearly wasn't for the correct printer.
Yes thanks, that is the question I was trying to answer.
Now one thing that the instructions are not clear on: it says that I need to have a POP server interval or I can receive ifaxes manually. I am not sure what the difference is (since it says if there is anything in the POP server it is printed anyway) and I also am not sure what settings to put in the POP server if I set up a gmail address. Help?
Also I put the username and PW for the email address I set up and I keep getting authentication errors when I check the connection in the remote UI. The manual is fantastically unhelpful here.
I'll reply back with help for this in a little bit.  I created some pictures recently that I think will be helpful for you.
Example Gmail:
Example Outlook
thanks this is a big help. After some time on the phone with Canon I also discovered that iFax only works with another iFax capable machine. Oh well. 🙂
