Canon m644 scan issue
rfausett
I went through the steps to define "TX settings" in Remote UI, using a gmail account. I apparently made the mistake of clicking the "LDAP Server settings". As a result, when I click the "scan" button on the printer display, it wants me to select an LDAP server from a list that has none listed in it. I checked the "LDAP Server settings" in Remote UI and there are none listed, as I only read the option details when I initially clicked it. The "scan" button did attempt to send a scan to email prior to my clicking the "LDAP Server settings" button in the Remote UI. Anyone have an answer?
I looked for a factory reset of the printer display but aparently Canon has to do that.
Log into the printer's Webserver from a browser, and make your desired changes.
Disable LDAP, reset, (yourself), etc.
Starting the Remote UI:
Starting Remote UI - Canon - imageCLASS MF746Cdw / MF745Cdw / MF743Cdw / MF741Cdw / MF644Cdw / MF642...
Manu Options, Remote UI:
Setting Up Menu Options from Remote UI - Canon - imageCLASS MF746Cdw / MF745Cdw / MF743Cdw / MF741Cd...
Initialize Machine - ALL SETTINGS: (careful this does everything)
Initializing Settings - Canon - imageCLASS MF746Cdw / MF745Cdw / MF743Cdw / MF741Cdw / MF644Cdw / MF...
5 REPLIES 5
Thanks, I'll try it.
the Canon m644 Remote UI doesn't have "Initialize Machine" in the Menu Options, at least not that I can find.
I found it, thanks.
Good Work!
