01-03-2025 03:46 AM
Hi Team,
may I ask if Canon printer supports to use Mimecast SMTP?
model: Canon iR-ADV C5535
I tried to change the SMTP server from smtp2go to Mimecast SMTP, when I applied the change and tested the SMTP, it appeared an error 'Could not find the server. Check the SMTP server settings, the DNS settings, and the SMTP server status.'
SMTP server: de-smtp-outbound-1.mimecast.com or de-smtp-outbound-2.mimecast.com
the SMTP username and password are correct, and DNS I tried to use my internal company DNS and Google DNS, still had the same error.
and the port number I already changed from the printer, Port: 587
once I change the SMTP server and account back to SMTP2GO, the SMTP can work.
mail.smtp2go.com
I am wondering if the Canon printer SMTP server does not support the Mimecast SMTP?
01-03-2025 08:49 AM
Thanks for joining the conversation, NoNeedLogin!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
