09-01-2015 01:31 AM
I have a Canon Selphy CP910.
The ink cartridge is jammed in the printer and cannot eject.
How do I remove the ink cartridge.
This is the second unit I have owned that this happened. I replaced the unit with a new one, and it hapened again.
The removable cartridge will not eject.
Any ideas?
01-26-2023 09:52 AM
The ink cartridge released and I replaced it with a new one. When I attempted to print again, It would not and I got the following message: "No paper/ink! Check the paper & ink and replace if needed. L/P/C"
02-15-2023 05:02 PM
Every new ink cartridge I put in does the same thing with the plastic film breaking and the printer jamming. Can this be resolved or is the printer history now?
02-17-2023 10:05 AM
The SELPHY CP910 is an older model which we have since retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
