SELPHY CP1500 Windows driver availability
HamEnt
Canon Selphy CP 1500 does not have a Windows 10 driver for USB connection with computer but the CP 1300 driver works !
9 REPLIES 9
iulianbogdan
Hello! I have a CP1500 and didn't found any driver. Just found your post and I'm curious if you are saying that driver for CP1300 is working with CP1500 too, or you say that for CP1300 there is a driver and it works? Thanks!
MattRo
Has there been any update for Windows 11 drivers. The Microsoft IPP Drivers automatically updated and now the 1500 Selphy printer options are only A4 or Letter paper size (no Japanese Postcard) and only grayscale (no color).
When comparing to a Windows 10 PC I can see the correct settings in the printer properties but I cannot see them in the Windows 11 PC.
When will Windows 11 Drivers be made available for the 1500 Selphy Printer?
MattRo
Windows 11 Driver - The most recent updates to Windows 11 have made the 1500 Selphy useless. The previous Windows 10 IPP driver (version 19041.1) worked correctly ... the most recent IPP driver (26100.1) does not work as it does not provide Japanese Postcard paper size options or color printing.
This renders the 1500 useless with a Windows 11 PC and using an app on a phone is not an option in our business and store application.
What are Canons plans to remedy this situation?Canon 1500 Selphy Driver Details - 100625.jpgDriver Advanced - 100625.pngScreenshot 2025-10-06 144745.jpgWindows 11 IPP Driver - Not Working.png
konio124
I'd like my money back! The printer is currently unusable with Windows 11 H25H2. Is Canon going to fix this?
It seems to work wirelessly, but error on USB connection.
It does not work wirelessly or with USB with the latest updates to Window 11.
Windows 11 have removed support for Japanese Postcard and Color printing for this generic printer driver and unless Canaon are willing to create a dedicated Canon Driver (as they should do) then this printer is useless with Windows 11.
I am now in the process of rebuilding a PC with Windows 10 just to enable me to continue to use this printer for our business application. If this is not the definition of the cart leading the horse then I am not sure what is.
Canon need to step up here and provide a dedicated driver for this printer to maintain compability with Window 11. This should not be difficult or challening for a company the size of Canon.
Anything less than this will speak volumes to the Canon lack of customer focus or support.
I agree with Konio124 in terms of money back or a working driver. They are they only two acceptable paths forward.
Over to you Canon ...
Interesting; I got it working via USB now but won’t work via WiFi now - just gives the option for letter or A4 paper. I can’t even explain how the usb started working - it just did this morning. I’m on day 2 of printer ownership and don’t want to have to return it over something so simple - they say it works with PC, so it should. I spoke to Canon support today about it not working via WiFi and they had no solution beyond updating firmware (?) but blamed Windows updates. Insisted drivers are not necessary. I tried CP1300 drivers per another post, but no luck.
amekitty
Constant connectivity issues. Changed wires, reset it multiple times, attempted to print off just the mobile app, but still have connectivity errors. Please help us find a solution! Tired of warranting out over and over.
emcee
After having it working, not having it working, then having it working again, I can safely say that this printer will not function with windows until Canon releases a driver. Based on everything I have read, windows has scaled back their support of printers, particularly with custom paper size and pushed the ownership of those drivers to the manufacturer. Cannon is aware of the issue, but there is no way to get an update internally. I spoke to someone from support this week because my printer is useless to me, but is just over the return window (I’ve had it about 45 days). I asked if I could somehow create a ticket internally and have this escalated but they told me no and that basically it’ll get released if/when it gets released. I did let them know that this printer is still being sold under the guise of functioning with Windows 11, which seems like false advertising to me.
nothing anyone can do unless someone knows how to make a driver. That would fix all the issues. My printer was working for three days straight, and then I went to go print photos and suddenly Windows didn’t recognize it. After multiple installation attempts, I had to give up. If I would’ve had a driver, that issue would’ve been fixed in less than a minute.
