05-25-2024
05:42 AM
08:48 AM
Hello,
I use Selphy printers after a switched power board. Usually it is necessary to press down the power button to start the printer...
I'm searching for something like "auto power on".
Is there a way turning on the printer if main supply (220V to power adapter) will be switched on without pressing down the power button?
Thanks
09-19-2024 09:57 AM
Hi, did you find a solution for what you where looking for ?
I'm trying to do the same, but can't find anything...
01-01-2025 04:30 PM
Hi, you find a solution? I have the same problem. I want to use it for my Photo Booth.
04-09-2025 04:32 PM - edited 04-09-2025 04:32 PM
Hi rogle,
This is not a feature that is available with SELPHY printers.
