08-27-2022 08:17 AM - last edited on 08-27-2022 09:18 AM by Danny
Keeps saying failed to communicate to printer. Both printer and phone are on same network. And it has been granted local access on the app. So now what?
08-30-2022 12:18 PM
Turn the printer off, restart the router and then turn the printer back on once your network is up. Confirm the printer is still on the same network, then remove and reinstall the Canon print inkjet/selphy app and try to print.
08-27-2022 08:27 AM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know the exact model Canon equipment you are using and which operating system is running on your computer (i.e. Windows or macOS, and which version). Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
08-27-2022 09:07 AM
It is the Canon Selphy CP1300. And I am trying to print from my mobile app on my iPhone. I do not own a computer.
08-30-2022 12:18 PM
08-30-2022 08:55 PM
That seemed to have done the trick. Thank you
05-07-2023 10:23 PM
I have done this several times and it is still not working. Any suggestions??
Thanks
05-10-2023 01:24 PM
Are you using a home network or a personal hotspot or mifi type of connection?
05-16-2023 09:50 AM
Hi, same for me. I've tried resetting the router but my phone (Google Pixel 7 Pro running on the latest version of Android 13) can no longer find my CP1300 Selphy printer.
They are both connected to the home network, I've checked the details several times and everything matches but no connection can be made since the last Android software update.
09-07-2023 08:26 PM
This solution doesn’t work. It is an interim fix but the issue keeps happening. Not sure if there is a version. Update needed to software but you shouldn’t have to reinstall app over and over on iPhone or iPads. Maybe this is specific to apple connections to the printer. Please help
11-30-2024 12:08 AM
This solution is not working for me. Any other ideas? Iphone 13, Home Network, Direct connection failed, downloading the drivers on a Mac Laptop FAILED. The printer is connected to the WIFI network just fine. I reset the router, reinstalled the apps, have disconnected and reconnected the printer and power cycled everything several times. The printer will not show as a listed option on the Canon Print App. I have also tried every country or region in the app. This is the first time I have not been able to get this to work.
