02-08-2021 05:09 PM
Hi, very beginner question about lenses here.
I have a 3rd hand Canon EOS 5D, but no lenses to go with it.
I think I'd like to go with the EF 24-105mm f/3.5-5.6 IS STM but want to make sure first that is is compatible with the camera.
Is this an EF mount camera?
I guess I'm wondering which of these types of lenses I can use with this older model camera.... Mount EF, EF-S, or EF-M
02-08-2021 06:16 PM
Canon EOS 5D's are all EF mount, so can use any EF lens.
Go to this link and filter by a Lens Type of "EF Lens" for the full list of Canon EF lenses.
02-08-2021 06:16 PM
You can use only EF mount lenses, since the 5D is a full frame camera.
02-09-2021 10:05 AM
"You can use only EF mount lenses,..."
This is true if you stick with Canon lenses but off brand may not have the EF designation. Sigma for instance calls their EF mount lenses DG. They will also work on your 5D.
02-09-2021 11:19 AM
@ebiggs1 wrote:"You can use only EF mount lenses,..."
This is not entirely true. When Sigma uses the "DG" designation, it only means that the lens has full frame coverage. The actual lens mount itself could be for Canon EF, Nikon, F or some other mount.
02-09-2021 12:02 PM
"This is not entirely true."
However, we are not talking Nikon or some other brand camera. It is pertinent and entirely true. We are talking 5D. Right?
A Sigma or Tamron will not have "EF" written on them. A Sigma, for instance, not for Canon EF will have DC written on it.
Not that I am recommending the OP go for off brand just clearing up the nomenclature if he was expecting to see EF on all lenses for a 5D.
02-10-2021 06:17 AM
@ebiggs1 wrote:"This is not entirely true."
"...Sigma for instance calls their EF mount lenses DG...."
