sensor damaged due to mirror
malengarcia
Has anyone had problems with their sensor  being scratched due to faulty mirror on Canon 5D MK2?Thanks.
10 REPLIES 10
MikeSowsun
I have never heard of mirror problems with the 5D Mk II. Only the original 5D had mirror problems. It also seems very unlikely for the mirror to damage the sensor as it would have to make it's way past the shutter curtain in order to reach the sensor.
Mike Sowsun
TCampbell
I can't imagine how this would be possible because of the way the mirror moves.
BTW, there are two filters in front of the sensor -- the front-most filter is the filter with the piezoelectric effect which vibrates the filter to shake dust loose. That's the filter which can get dust on it and it's also the filter which, if cleaned improperly, could become scratched.
The mirror mechanism does have an expected lifetime and it is a part which is expected to eventually need replacement. But that's something Canon can do.
Tim Campbell
5D III, 5D IV, 60Da
Thanks for the posting. I took my 5dMk2 Canon service for cleaning ,and was told my sensor has scarches on it. First time ever to have it cleaned ., since I bought in Jan2009. never touched the inside nor swapped lenses, that's why I wondered how it happened. Only thing I could think of are 3 possibilities: factory defect, faulty sensor cleaning mech., or service technician's fault. What do you think?
It could be a factory defect, or been scratched by the Technician, but I can't imagine the camera's built-in sensor cleaner scratching the sensor. It just vibrates the front layer (low-pass filter).
If you bought the camera 2nd hand, I would suspect the previous owner may have scratched it while cleaning the sensor.
If you bought it new, and have never noticed a scratch in your images, I suspect the technician is :
1) being overly critical of some minor imperfection
2) damaged it himself and is trying to cover his ass
I would tell them to return the camera as is. Then when you get it back, have a look yourself to see just how bad it is. If the scratches do show up in your images, you will know it happened after you sent in to them.
Mike Sowsun
Thanks so much Mike! It 's a brand new Canon 5D MK2 ,when I bought in 2009. It's the first time I had it cleaned because I only have the 24-70mm lens stuck there, and had never opened nor attempted to clean the inside(I am very very careful with my stuff.).I thought taking it to service center in Sydney would be a great idea.But I was disappointed.They are not owning up to it.....I've taken it now to the Tribunal.
Did they show you these scratches?  On all my years of being in photography, I've never known anyone to receive a factory-new camera with a scratched sensor.  I'm not saying it cant happen... but it would certainly be exceptionally rare.  The most common way to get a scratch on the sensor is through improper cleaning.
Let's test it.  Do the following:
Find a "plain" white wall (or ceiling).  The most important thing is that it be plain - no colors, no pattern.  For this test you don't even have to focus the lens.
Set the camera to Av mode, then crank it to your highest f-stop (which on the Canon EF 24-70mm f/2.8L - that's the lens I think you have - is f/22).
Take a few shots of the wall.
Import them onto your computer.  If there is anything "on" the sensor (and btw, this is technically one of the filters in front of the sensor) then when you shoot at highest possible f-stop, it's shadows and optical effects will show up in the image.  It doesn't matter what the camera was focused on or if it was even focused at all ... because you're really just using the plain white wall as a flat illuimination source and basically what you're really doing is trying to get an image of the filter.
Canon can replace that filter... it's a bit of work to get at it (it can only be accessed by disassembling the back of the camera.)
If you go to this page and scroll about 1/4 down you'll see the "sandwhich" of filters that are stacked inside the camera just in front of the sensor.
http://www.imaging-resource.com/PRODS/E5D2/E5D2A4.HTM
I do just occasionally have to clean the sensors on my cameras and since this is sort of like occasionally needing to change the oil your car -- it's something every owner should either learn to do themselves or find a reputable shop to handle it (Canon actually offers this service.)
If there is anything on the sensor and you want to simply shake it loose, the easiest thing is to remove the lens (in an appropriately clean location of course -- you would not want to do this in the middle of a sand-storm), point the camera at the ground and navigate to the self-cleaning menu and let the camera have a go at cleaning itself.  Often times this is all it takes.
If that's not enough, I have a hand-squeezed blower (such as a "Rocket Blower" brand blower).  I discourage the use of those cans of compressed air because if the can is shaken or not held perfectly level, then the can will spit out it's own propellant material.  This leaves a foggy residue and if that got on the camera sensor (really filter) it would have to be "wet" cleaned - no getting around it.
When you use a hand-squeeze blower, keep in mind that you don't want the tip of that blower touching the sensor and scratching it up -- so take appropriate care.
if that doesn't work, sometimes a _very_ soft bristle brush will do the trick.  I have a small cleaning brush that I use and it doesn't get used for anything else.  Avoid touching the bristles with your hands as this can tend to leave skin oils on the bristles.  They do actually make versions of these brushes with a grounding wire - the idea being that if the dust is clinging to the sensor due to a static "cling" effect, the grounding wire will let it release that charge and it should be willing to let go.
If that still doesn't work, I ultimately go on to "wet" cleaning... but before I do this, I want to get a magnified view of what I'm dealing with.  You can get various types of magnifying loupes to inspect the sensor.  They make some with lights inside and which rest on the lens-mounting flange, giving you a nice magnified view so you can carefully inspect the situation before you have at it with anything more aggressive.
This is important because if there is a bit of debris stuck on, you don't want to be using strong pressure with a swab and then "dragging" that debris around the surface.
I use "Eclipse" solution (made by "Photographic Solutions") and their "Sensor Swabs".  The sensor swabs come in sizes.  A "Type 3" swab is sized for full-frame sensor cameras.  The "Type 2" swab is for APS-C sensors (the difference is the width of the swab.)
Rather than following typical instructions and taking a swipe across the full surface of the sensor, I put 1 to 2 drops of solution on the swap and then lightly "daub" the spot with the offending material.  I want to see if I can't tease it off the sensor and get it to cling to the cleaning swab.
Throw that swab out!  Do NOT re-use (don't be cheap... if you think the swabs are expensive, consider the cost of the filter replacement.)
Once the offending material is gone, then I'll take a fresh swab, put 2-3 drops of solution on it, and then give it a gentle swipe across the surface -- no need for any pressure here.
Eclipse solution in near pure methanol and will evaporate on it's own and leaves no residue behind.
That's it.  You're done.  Switch off the camera and put everything back.
I can tell you that with regular care, the camera's self-cleaning or the hand-squeezed air blower will take care of whatever is on the sensor in the vast majority of situations.  I almost never need to go any farther than that.
Tim Campbell
5D III, 5D IV, 60Da
Hi Tim! Thanks for your posting. The scratches on the sensor was ONLY after the service cleaning(as far as I know)because I've never opened the camera nor attempted to clean anything inside. I took it to Tribunal in Sydney BUT guess waht???
Canon Australia does not own up to it. They said that they will not accept any responsibility toa scracthed sensor. They said that -the scarcthes may only be minor that it wont affect my shots. It's not the issue -the issue is ghe sensor had scratches after the sensor cleaning of their technician. They only offered a certain amount BUT I still have to pay $500 to replace my CMOS sensor(which I did not scratched!!).
The bottom line-   DONT TRUST CANON!!!!! They dont care about you nor your stuff.
malengarcia
HI guys!! After meeting with Canon technician and their paralegal rep at the Tribunal office in Sydney, Canon did not accept any responsibility for the scratched sensor. I have to pay $500 for repair of CMOS sensor and they will shoulder 1300. BUT why should I pay if I did not scratched it???
So the next time you want to take your camera for service at Canon- THINK HUNDRED TIMES and PLEASE make sure you take photos of your cameras ,lenses before servicing. And dont trust them- they dont care about you nor your photographic equipments which you bought from them.
It is not possible to "scratch" the CMOS sensor itself.  Only the front-most filter can be scratched.  That's the only surface that's exposed when the shutter is opened.  It's not actaully possible to "touch" the filter layers behind it nor of the sensor itself.
If anything were to be replaced, it would be that filter.  The filter does have a piezoelectric element attached to it (which is what makes it vibrate when the camera goes into self-cleaning mode.)
Tim Campbell
5D III, 5D IV, 60Da
