03-24-2013 06:19 PM
I am getting a message saying NO MEMORY CARD in my Powershot SX20IS . I have tried removing the card also tried using a new card. Nothing is working. Is there something else I can do? I really like this camera and would love to use it again.
Thanks,
Eileen
03-24-2013 06:25 PM
Have you been using the camera regularly up until now, and it just suddenly stopped working? If you were using your card in a different camera, or if you are using a brand new card, did you "FORMAT" the card in this camera before trying to use it?
03-24-2013 06:33 PM
Hello,
I did use the card in another camera. But, I also tried other cards that were formatted.
Eileen
03-24-2013 11:25 PM
Exactly what card are you trying to use in what camera. Many new cards can't be used in cameras designed before the newer card specs became standardized.
03-25-2013 05:02 AM
I mention in my first post I have the Canon Powershot SX20IS and I am using the SanDisk Ultra 4GB memory card.
03-25-2013 06:43 PM
Other than a broken camera, there are 2 possibilities with the old card:
1.) Old card is now dead, or
2.) Old card is OK, but was reformatted to the other camera, and you need to reformat it in this SX20IS.
I would test the old card as follows:
1.) Is old card now dead? Try it in your other camera and see if it works there.
2.) Old card was formatted for new camera and needs to be reformatted by the old camera? Try reformatting it in the old camera.
As for the new card:
It could be that as Cicopo says it is too new to work in the old camera. I would nevertheless try reformatting the new card in your old camera just to be sure.
As for the camera:
It could just be dead, but if it was working fine last time you tried it, and it has not been dropped, nor stored in a hot storage unit or something, it seems odd for it to have died while not even being used.
03-25-2013 07:56 PM
I can not figure out to format when the camera is saying that there is no card to be formated.
Thanks for your help, it might just be the camera and not the card. I have tried other cards.
