01-31-2013 01:17 PM
On the L100 phonefax, how do you know that a fax was sent successfully?
02-03-2013 05:34 PM - edited 02-03-2013 05:35 PM
Hi Larry2,
There are a few ways to confirm if a fax has been sent successfully:
1. An error report is not printed.
2. You can check the Status Monitor for the last fax sent.
3. You can print a Communication Management Report.
4. You can program your fax machine to automatically print a confirmation report after each fax sent.
If you need to print a report for recent faxes sent, first make sure A4 or LTR sized paper is loaded:
Press REPORT, scroll to <PRINT REPORT LISTS>, [OK], scroll to <COMMUNICATION MANAGEMENT REPORT>, [OK], [OK] that paper is loaded, [ < ] to highlight <YES>, [OK]; press REPORT to exit.
If you want a report to automatically print after sending a fax:
Press REPORT, scroll to <REPORT SETTINGS>, [OK], scroll to <COMMUNICATION MANAGEMENT REPORT>, [OK], <Auto Print...>, <ON>, [OK]; press REPORT to exit.
If further assistance is needed, find more help at Contact Us.
08-26-2015 01:59 PM
I tried but on the auto print...
on the machine choice said auto print after 40.....
I don't want to print after 40 faxes.
I want it to print auto after each fax sent.
03-30-2016 04:47 PM
08-22-2018 04:25 PM
I have the same problem, does any one have an answer ?
08-22-2018 04:31 PM
I want a report after each fax sent not after 40. I tried this your solution and it did not print a conformation after each fax.
