06-26-2020 06:03 PM
How do you move a shortcut to the main menu from the quick menu? I am trying to move the my image garden shortcut to the main menu.
Thanks
06-27-2020 10:28 AM
I believe placing a checkmark on the icon will add it to the Main Menu:
https://ugp01.c-ij.com/ij/webmanual/QuickMenu/W/1.2/EN/QM/qm_01.html
06-29-2020 03:06 PM
Hi barryb1717.
All functions for a printer or scanner will show up in the Quick Menu's main menu; they may be dragged and dropped to either arm of the L-shaped Shortcut menu.
If you have more than one compatible Canon product installed, you can change the Printer and Scanner options using the drop-down menu at the bottom of the Main Menu. More information may be found in the Quick Menu online manual:
