04-22-2014 11:24 AM
Hi Everyone! I'm Tim, a senior technician here at Canon. I'm going to be here on the Canon Forum, live later today, from 3:30-4:00pm EST to kick off a community discussion on Nature Photography! I'll be here to answer your questions, provide tips and bounce ideas around, so drop on by and join in on our conversation!
I'm a long time photographer with over fifteen years of technical and photographic experience with Canon and the imaging industry. I particularly enjoy working with full-frame cameras and Canon's Cinema EOS gear, and take every opportunity I can to capture the beauty of the Atlantic Ocean near my home.
04-24-2014 02:50 PM
@ebiggs1 wrote:
No matter how many pretty pictures you show with colored lines on it, no crop takes place.
Evidently the concept of something being relative to something else is beyond you.
The Nikon D800, their mega megapixel full frame camera offers a crop mode that does, literally, crop out part of the image. While you can argue the usefulness of such a feature, it exists. The camera also allows you to use DX lenses ("APS-C lenses") on a full frame camera when in one of those crop modes. I would hope that when Canon enters the 35+ MP arena that they offer something similar.
@ebiggs1 wrote:
Nobody tries to claim P&S's are crop cameras. Are 4x5's considered enlargement cameras? No. Because this is all photographic jargon to try and explain the relationship of the focal length of the lens. You are entering a time where lot's of people never used a film camera so "crop camera" is actually meaningless to them.
P&S, MF, and LF cameras don't share lenses. FF and Crop do. It's relative. It has nothing to do with using film, and there are thousands if not millions of new camera users that never shot film that aren't having a difficult time understanding the concept.
04-24-2014 03:45 PM
Boy I feel like I am teaching Photography 101 to you. But here goes, again.
Smaller, non-DSLR, P&S, can also be characterized as having a crop factor relative to 35 mm format, even though they do not share interchangeable lenses. Example, the so-called "1/1.8-inch" format with a 9 mm sensor diagonal has a crop factor of almost 5 relative to the 43mm diagonal of 35 mm film. These cameras are equipped with lenses that are about 1/5th the focal lengths that would be on a 35 mm P&S film camera. Sometimes manufacturers label their cameras and lenses with their actual focal lengths, but not always. Some have chosen to instead use the crop factor and label the 35 mm equivalent focal length.
This same procedure stands for larger format camera except in the reverse.
04-24-2014 04:06 PM - edited 04-24-2014 04:14 PM
"Would just like to clarify, ..."
clars,
The term crop factor has confusing implications. A similar term could be "focal length multiplier". (FLM) It is often used sometimes for this reason.
Lenses, of a given focal length, seem to produce greater magnification on crop-factor cameras than they do on full-frame cameras. This is an advantage for say bird photography, where photographers often strive to get the maximum "reach".
A given lens casts the same image no matter what camera it is attached to. There is no crop. The actual specification that does change is “angle of acceptance”. Plus there are other factors to consider too like DOF (depth of field). Which will be exactly the same is the projected image is exactly the same, BTW.
The best advice is to forget the term crop camera or crop factor and get a lens that shows you, in your view finder, what you want. Whether it is a 300mm, 480mm equivalent or whatever.
This is just the surface of factors that determine what an image looks like in the end.
04-24-2014 06:27 PM
@ebiggs1 wrote:Boy I feel like I am teaching Photography 101 to you. But here goes, again.
A quick jab, and then go on a tangent that has little to do with the discussion and something I already know. Obviously we're not going to come to any sort of agreement.
I'm sorry you don't like the term, but unfortunately it's not going anywhere so long as 35mm and APS sized sensors rule the market. And even then, it'll probably stick around. I still carbon copy people on emails...
