My image Garden
timfc0649
Every time I try to use My Image Garden, my computer freezes and I have to hold the power button to shut down completely, then re-boot.  Printer is MG5420, Computer is Dell Inspiron 1545, Intel Core 2 Duo 2 ghz, 4gig ram, Windows 7 Home Premium.
So far I have been unable to use My Image Garden, and therefore I cannot print on discs (my main reason for buying this printer).
Anyone else having this problem? Any solution?
20 REPLIES 20
cscarbor
I have the problem of My Image Garden freezing also.  Specifically when I scan (from the menu from the screen or from the LCD menu on the printer).....same thing happens.....it scans my document, but then it shows the My Image Garden on the screen.....but it is frozen and I have to go to Cntrl-Alt-Del and select My Image Garden, then punch "End Task".  I've tried uninstalling My Image Garden and re-installing it, but that does not work.
jeffmaz
I have a Pixma 922mx inwhich I use Image Garden to print CDs. It usually goes fine, but suddenly in the dialog box it blows up the disc image and moves it off center and it gets to print that way see here:
badprintalign.pngSo I've looked on the boards and searched on Google and haven't found a fix. Could it be my upgrade to Mac OS 10.11.6: (Elc Captain) of do I need to upgrade the OS or...
What could be the fix??
I'm disappointed that Canon doesn't have an easy path to solving issues.
Louise3
I cannot print from my image garden?? Error message is being displayed 4102- change media type and paper size. I've done this several times but still not printing. I've been able to print with other printing software, but not image garden :smileyfrustrated
Still no answers. Print dialog now omits the graphic view.
HappyG
Same problem.
all the other tools in the canon suite work except my image garden....it goes non responsive and i have to end from task manager.
Very disapointing considering i have just bought the printer and installed drivers and software direct for canon as instructed in set up (assumtion here is that this is the latest revision of the software)
What is the fix canon?.
"What is the fix canon?"
Call 1 (800) 652-2666
EOS 1DX and many lenses.
I ended up using InDesign and finding a CD template online which I reworked to design any CD. I must say is works perfectly, just takes longer. Print dialog box and everything works. My Image Garden was easy for q2uick stuff. Sorry the techies at Canon can't seem to or don't want to fix it.
I have Win 7 x64 system, and the darn software freezes each time I give a command. I may be lucky to have one print, but then it's stop. Some times I can press Alt+Ctrl+Del and shut it down, other times I have to reboot the computer to be able to restart My Image Garden as it won't respond to a restart of it. I have looked for updates but apparently there's no update since january '18. I love how I can stop the printer from expanding the borders when I do a full page print, but when you can only do a print once in a while it's not worth it unless it's just for a page or two. I see no Canon support is replying to any questions so I guess I'll just have to stick with prints from Photoshop Elements and scrap the full page prints.
I too have the problem of MIG starting but then freezing on the start screen. I am using Win 10. Have to use task manager to get going again.
Michigan_PI
This is probably the WORST program I have ever used. It constantly crashes, you can't save your work in a way that it can be backed up or accessed.
I cannot believe that a company such as Canon is not embarrassed to even offer such a crappy product!!
That being said, what other option is there to design and print on disks that works with the MX922?
Or do I just need to send it back to Amazon?
