09-11-2018 09:02 AM
I have moved from Easy Photo Print to My Image Garden and have difficulties printing my photos, putting several little ones on one page.
With Easy Photo Print I was able to add photos of different aspect ratios (e.g. taken on my smartphone, some others with my camera) - and they were printed keeping their aspect ratio (means: some were wider, but all had the same heigth).
With My Image Garden the photos seem to be "inserted" into frames that have a certain aspect ratio (seems like 4:3 but I am not sure). If the photo that's inserted has a different aspect ratio, the photo is cropped on the left and right side.
I can manually resize the frames to match the aspect ratio a little bit better. But I want to have frames that exactly match the aspect ratio of the photo inserted.
I did not find any function that says anything like "fit frame to aspect ratio of picture inserted" or so. Is there anything like that? If not, do you have any ideas?
09-12-2018 09:10 AM
Hello.
Cropping the image should allow you to adjust the aspect ratio as necessary. Visit the following link for details:
My Image Garden Guide - Cropping Photos
09-12-2018 09:23 AM
09-12-2018 09:42 AM
Hi danielhendling,
There isn't an option in My Image Garden that would allow for frames on images of various aspect ratios.
09-15-2018 07:49 AM
OK. Can you tell why this was possible (it was standard, so not even an option) with EasyPhotoPrint and why it has been removed for My Image Garden?
