12-01-2016 06:49 AM
i have here an old microphone Canon MM-200. Can somebody tell me what DC power this microphone needs. I would try to use it on a other camcorder (Panasonic V770) buth it does not work
kind Regards,
Henk Waegebaert
12-01-2016 03:55 PM
@henkwa wrote:i have here an old microphone Canon MM-200. Can somebody tell me what DC power this microphone needs. I would try to use it on a other camcorder (Panasonic V770) buth it does not work
kind Regards,
Henk Waegebaert
Is that the correct full model number for the microphone? if so, then that microphone is too old for the internet. Panasonic makes a few V770 microphone models, with different letters on the end..
12-01-2016 04:37 PM
I got the mic from a friend. He got it from his father.
It's really a mic from Canon. The name Canon is on the mic and on the box.
It's a stereo mic and it has an audio input connector.
So when you are filming, you can mix an external audio signaal with the sound that the stereo mic is captering.
I'm from Belgium (Europe). Maybe it's a model that has only been sold in Europe? But it is a mic from Canon (made in Japan)
12-01-2016 04:58 PM
What wadizzle means is that his Google-Foo failed.
Your best bet might be to see if what documentation you have and see if it lists any compatible cameras and look for the manual for *those*, the specs might list any phantom power capabilities.
Remember, Canon makes consomer to pro to very pro video equipment.
12-01-2016 05:21 PM
That's the problem. I have no documentation and on the internet , there's nothing to find about this mic. Very rare microphone i think.
12-01-2016 06:03 PM
Did you try to call Canon at the support number? A Canon person on this board let slip that the support folks have one of everything Canon has ever made. They might be able to help.
12-02-2016 11:37 AM
I have uncovered the fact that it was released circa 1988.
12-02-2016 11:40 AM
Hallo Waddizzle,
Thanks for the research.
Henk
12-09-2016 10:00 AM
I received a manual from a person in Belgium. The mic needs 5V DC on the smallest minijack.
Problem solved!
07-27-2020 12:19 PM - last edited on 07-27-2020 12:23 PM by Porcha
Dear henkwa, would you please e-mail me a copy of the MM-200 manual? If so, (information removed as per Forum Guidelines). Thx in advance, Bob.
