08-08-2014 06:54 AM - edited 08-08-2014 06:55 AM
Canon sx 260hs you tube states it is battery life and every time I place a fully charged one in the number is totally different either lower or higher. How can that be possible? Can I get rid of that off the lcd screen?
Is it really beneficial to have the gps logger on always? or gps is good enough on its own?
Thanks in advance.
08-11-2014 06:19 AM
hcgolf4fun,
You are correct that 48'23" is the remaining shooting time available. In this case it is 48 minutes 23 seconds. You can toggle the amount of information that is displayed on the screen by pressing the DISP button. However, it is not possible to remove a specific item from any particular display setting.
08-08-2014 08:51 AM
"Is it really beneficial to have the gps logger on always? or gps is good enough on its own?"
In order for the GPS to work properly, it must be on at all times.
08-08-2014 09:21 AM
Thank you
08-08-2014 09:37 AM
I have read in this forum when it states on the LCD screen - eg 48' 23" means it has 48 hours 23 seconds of recording time so therefore that number only refers to video recording. How can I get it off the screen since I don't use the camera for video taping?
08-11-2014 06:19 AM
hcgolf4fun,
08-11-2014 07:20 AM
Thank you for the info.
