04-17-2014 11:16 AM
I have tried everything but MP Navigator EX still it will not start. All I get is Box that says: Cannot start MP Navigator EX. Check the following point. 1. The supported model of this software is as follows. Check your product model listed. Cannon MX880 series
When product model is not listed install correspondent MP Navigator or MP Navigator EX
2. MP driver/scanner driver which supports your product model is installed
3. Your model product is connected to PC properly and the power is ON, if there is a power supply
4. Reconnect the USB cable when connected with USB..
Hi have WIFI just to let you know.
I have done verything in the Web but still it won't work.. Can someone please help
I have Windows 7/ 64 bit |
05-05-2014 08:59 AM - edited 05-05-2014 09:00 AM
Hi tdenbrock,
If you have any antivirus or firewall programs on your computer, please temporarily disable them and then try to launch MP Navigator again. If you still have difficulty opening MP Navigator, we can remove a file/icon on your computer named "My Websites on MSN" to see if this will resolve the issue. To do this, please follow these steps:
1. Click 'Start' and then 'Computer'.
2. On the left-hand pane, click the down arrow beside Local Disk C: .
3. Click the down arrow beside Users to open the folder.
4. Click the down arrow beside your username (for example Joe).
5. Click the down arrow beside the AppData (Application Data) folder.
6. Click the down arrow beside Roaming.
7. Click the down arrow beside Microsoft.
8. Click the down arrow beside the Windows folder.
9. Click the down arrow beside Network Shortcuts folder.
10. Locate an icon named My Web Sites on MSN.
11. Right-click on My Web Sites on MSN and select 'Delete'.
After performing the steps above, please try to open MP Navigator again. If you still receive the same error after removing the file, or if the file does not exist, we can try to temporarily remove files from a folder called TWAIN 32 that may be causing a conflict with the MP Navigator program to try and resolve the issue. To do this, please follow these steps:
1. Go to Computer / My Computer and locate the C: drive, then double-click on it to open.
2. Locate the WINDOWS folder, then double-click to open it.
3. Locate the TWAIN_32 folder, then double-click to open it.
4. Inside of the TWAIN_32 folder, you will see a folder for your PIXMA MX880 series printer as well as a WIATWAIN.DS file. If there are other files in that folder, you will want to move them to another location, preferably your Desktop by doing the following:
4-1. Click on each of the other items in the folder other than the the WIATWAIN.DS file and PIXMA MX880 series folder to select them. You will want to hold the the CTRL key on your keyboard while selecting each of the items until all of the items except for the two referenced above are selected. Please be sure to leave the WIATWAIN.DS file and PIXMA MX880 series folder inside of the TWAIN_32 folder.
4-2. With all of the items you want to move selected, please go to the EDIT menu and select the CUT option.
4-3. Go to your Desktop (main window that comes up when you start Windows with all of the icons on it) and right-click your mouse in any blank area, then choose the PASTE option. The items you selected from the TWAIN_32 folder should appear on the Desktop.
5. Try to launch and scan using MP Navigator again.
Hope this helps!
06-09-2014 04:27 PM
I am getting the same error as reported. I've been using this printer and MP Navigator EX 5.1 for a year with no problems till today. This is the same computer with Windows 7 64 bit. I followed the listed instructions without success. I've reinstalled the drivers and uninstalled and reinstalled MP Navigator EX 5.1. Hope you can find a solution soon. I use this scanner almost daily.
06-09-2014 04:33 PM
04-14-2015 08:12 PM
I know this is a bit old now but I spent a bit of time trying to get this program to work after it just randomly stopped working one day.
Tried uninstall, reinstall, did everything bar reformat the computer to get it working again (wouldn't even work via USB even though I use the network for printing with no problems at all).
Turns out - just right click on MP Navigator and select "run as administrator" and it works fine again! hallelujah
If you're not aware you can avoid doing that every time by going down to properties, selecting the compatibility tab and ticking 'always run this as administrator' down the bottom.
03-12-2017
04:12 AM
08:50 AM
03-13-2017 06:51 AM
Hi Adelkinawy,
What is the model number of the Canon multifunction printer that you own?
04-29-2017 03:50 AM
I don't know what her model is, but I'm using the CanoScan LiDE 200 with a Windows 10 64-bit OS. I am having the same issue and have removed the MSN folder; however, the TWAIN_32 folder looks completely different, likely because I have a different model scanner. Could you let me know the instructions to try to get it working? I also tried turning off the Firewall but no luck.
Also, is there any way just to update the basic Canon scanner menu to allow multiple page and PDF scanning rather than having to download additional software like MP Navigator?
Thanks!
12-02-2017 05:24 PM
I'm having the same exact problem. I have a Pixma MX32o which is supposed to be supported by the application.
12-29-2017 05:51 PM
I found a fix for my MP Navigator EX not opening and giving error message. I installed the printer software on my new Windows 10 computer and when I tried to open Navigator I get error message. I was trying to use it through wifi connection. I tried many sugestions on the internet and nothing worked.
To fix my problem I connected my printer to my computer USB port and the Navigator opened. I then disconnected the USB and tried opening Navigator through wifi and it worked. Apparently you have to initially open Navigator through USB connection before it will work with wifi connection. Hope this helps.
