02-25-2015 07:38 AM
I understand that the LP-E6n is compatible with the 5D3 and 5D2, but can anyone tell me if the newer battery can be used together with the older LP-E6 in a BG-E11 grip.
Thanks
02-26-2015 05:12 AM
Thanks.
Also, just received the following from Canon -
02-25-2015 09:25 AM
The battery is forward and backward compatible with the "N" version. Except having an additional 65 mAh of storage capacity (1865 mAh vs. 1800 mAh). It may make your battery level look off, though.
02-26-2015 05:12 AM
Thanks.
