08-27-2023
02:35 PM
08:33 AM
How do I find a list of the products that I have registered? This should be available, but I have not been able to find it. Info in, no info out?
08-27-2023 03:15 PM
After you log into My Canon, there is a tile in the nav pane called my products. It will show the products you registered most recently. Just above, there is a show all button which expands and displays all products you have registered.
08-27-2023 07:49 PM
Thanks Rick, but there is no title called "my products". What am I missing?
08-30-2023 01:40 PM
If you have registered printers in your Canon account but they are not appearing, I recommend reaching out to Canon support.
You will be able to access your support options through your account.
We look forward to hearing from you.
09-15-2023 10:01 AM
Your products now appear on the Account screen when you log in. If you don't see them, 2 things are likely. 1. you are not using the same credentials that were used to register a device, or 2. there is an issue with your user profile. Please contact support as ArthurJ suggested. They should be able to help you resolve it.
Canon Support - 1-800-652-2666
09-15-2023 01:39 PM
Thanks, I will check that.
