12-05-2023 01:52 PM
... Seems to be hosed. I see the button to click for the manual, but nothing happens. I tried with the S100 earlier today, and just tried with the T7 and neither worked.
I get to this screen:
But clicking on manual just loads the same page.
12-05-2023 02:11 PM
The page may be failing to scroll to the location of where the download links are. Recently, I have found that after clicking "Manuals", you have to wait a bit. The page may then scroll to the appropriate location. Otherwise, I will then manually scroll the page at which point the Manuals section is either expanded or still collapsed.
For the technical, looks like the javascript is going awry. Personally, would be great to just use more simplistic logic to allow navigation to a set of links to manuals.
12-05-2023 02:26 PM
There are no manuals, even if you scroll down the page.
12-05-2023 02:38 PM
Ah, I see. Yes, for at least those two products, seems they removed the downloadable manuals. So the Manuals button is probably pointing to some non-existant anchor on the page.
12-06-2023 08:51 AM
Hi, kvbarkley! We'll let our web team know about this. In the meantime, you can access manuals for the EOS Rebel T7, the PowerShot S100, and more via Support > Manuals at the top right, next to "Contact Us."
Hope this helps!
12-06-2023 09:03 AM
Could you provide us with the exact URLs you're landing on? Many products have a product page a distinctly different support page, the latter of which consistently let you access the product's manual library. We want to make sure everything works as advertised.
We look forward to your reply!
12-06-2023 09:14 AM
I think it is already fixed
