06-24-2016 08:47 AM
Hi, I'm fairly new to photography and my Canon T5. How can I avoid those reflections/circles I get when taking sunsets or moon shots. I tried not focusing directly at the light source but didnt help.
06-24-2016 11:42 AM
@funnybones wrote:Hi, I'm fairly new to photography and my Canon T5. How can I avoid those reflections/circles I get when taking sunsets or moon shots. I tried not focusing directly at the light source but didnt help.
What you're describing is probably lens flare. In inexpensive, underdesigned lenses, you may not be able to get rid of it entirely. But it helps to use a lens hood and to keep from pointing in a direction in which sunlight can reflect off the lens. And a cheap filter can sometimes make it worse.
06-24-2016 08:27 PM
@funnybones wrote:I'm usng a Canon EFS 18-55mm IS and a 75-300. It happens on either one. I mainly use the UV filter for lens protection but if that's contributing I won't use it
A good clear protective filter will cost over half the replacement cost of either of those lenses. You are better off skipping the protective filter, and keep using the lens hood.
06-24-2016 09:10 AM
You should post an example of what you're seeing in your photos, so that people can better understand your issue.
Common causes of what you seem to be talking about include cheap lens filters and the lack of a lens hood.
06-24-2016 12:50 PM - edited 06-24-2016 12:52 PM
Waddizzle - Probably the filter - I was using a hood
06-24-2016 10:33 AM
Remove the cheap UV filter.
06-24-2016 12:50 PM
06-24-2016 11:42 AM
06-24-2016 12:47 PM
Thank you Bob for the info on lens flare. That explains why it doesn't always happen. Not what I wanted to hear but will experiment with my shooting direction and maybe consider a better lens at some point.
06-24-2016 05:03 PM
06-24-2016 07:08 PM
06-24-2016 08:27 PM
