03-29-2013 12:53 PM
04-01-2013 07:35 AM
Hi Corr,
Based on what you are looking for, I recommend the VIXIA HF R40. It shoots in Full HD, has internal storage and it can be used with SD, SDHC or SDXC memory cards. You can also connect most self-powered stereo microphones that use a 3.5mm connector to it. It shoots great with indoor lighting and the format of the video should work with many editing platforms, like iMovie.
04-01-2013 07:35 AM
Hi Corr,
