06-23-2025 06:05 PM
I just bought a pair of 10x20is binoculars. The two images converge fine when viewing objects at a distance, but when I view objects 7-10' away, I need to twist the objective lenses all the way to the center to get the image to even come close to converging. Is this normal, or did I get a bad pair?
08-02-2026 10:31 PM
Do you really twist the OBJECTIVE lenses? If yes, No idea. If no, is your interpupilary distance too small for the binos? To check have someone with a larger interpupilary distance see if they have the same problem. If they do not have the problem, then you may need different binos.
08-03-2026 08:20 AM
Never needed to use binos for short distances. Would the 10X have anything to do with your concern? 20 seems to be small for a 10X binos. Can't help otherwise.
08-03-2026 08:33 AM
Maybe it wasn't quite far enough? The the specs from the MANUAL say the closest focusing distance is approximately 2m (6 1/2 ft).
08-03-2026 08:38 AM
Make/model of binos? Are you wearing glasses? Do they have adjustable eye cups for varying eye relief? If you're talking about getting concentric circles at a distance then that changing when you do close focus it could be normal for your brand and quality of optics, and you might be expecting to have gotten a better result than the product it capable of. In other words it could be a "feature" rather than a "problem". Here is an AI answer for you to explore:
