Recommendations for lens filters and beyond
Ramsden
Whiz
Hi folks
Following my post on photography on a train journey, a few of you recommended I get  CPL lens filters to avoid glare. Quick check of my kit and unsurprisingly, they're weren't any!
Apart from one (photo attached) my filters are all  the UV type.
So a few related questions.
1) do you experienced guys carry a few filters and change them as the situation alters? If so could you please share some best practice.
2) are there any 'does and don'ts' when using filters? If so, what are they?
3) some of my filters appear to be stuck in the lens, which I suspect is the aluminum thread oxidised into the lens thread. So any advice on how to prevent this happening, as I've always been warey of applying substances to my camera.
4) and finaly, what is the filter in the photograph as I can't remember buying it and for what purpose. I suspect it was for landscape shots at sunrise or sunset
Thanks as ever
Ramsden
18 REPLIES 18
You really only need to purchase the magnetic ring for each lens. Then with one filter to can put it on the lens you are using at the time. No need to have a filter for each lens.
Hi John
Thanks, that's good news. I'll be interested to see how this works in practice. It will certainly save me a lot of money.
Ramsden
Hi again John
Could you please explain in more detail how this works with the different sizes?
I feel I'm being a bit dumb not understanding how the different sizes integrate.
Thanks
Ramsden
You get a filter for your largest diameter lens and step up rings that match that filter on female thread and each lens on the male thread.
Maven also recently introduced thread-less and extra strength thread-less step up and step down rings. You’d still need an adapter ring or splash adapter on each lens. The extra strength ones are quite strong and mainly designed for when you want to stack filters or use some of their heavier filters (like the diopters).
So as an example if the largest diameter lens you have is 82mm and you also have 67 or 77mm lenses. Buy 82mm filters and use step up rings to attach them to your other lenses. The only downside to using them is you won’t be able to attach your lens hood. They do however make magnetic lens hoods as well.
Thanks Jeff
This is quite fascinating. I never expected my post to deliver so many new ideas, and on such a simple concept as the filter.
I can see a visit to camera shop is now on the agenda, after first doing my research with you guys to guide me!
Thanks as ever
Ramsden
Hi Jeff
Just clarifying my shopping list.
Ive currently got 7 lenses for my EOS90D and luckily some of them have the same thread size.
So my smallest is 52mm
2 x 58mm
3 x 67mm
1 x 68mm
So I order a 68mm filter
A 52, 58 and 67mm adapters- are these magnetic?
A magnetic hood
But Im not sure how to order the step up rings.
Great if you could check this over and advise on the step ups. Would that  be '52 to 68 step up ring'  ?
Kind regards
Ramsden
Apologies
My smallest is 49mm
Largest 67mm
And I can see the step up rings on line.
Sorted
Thanks
Ramsden
Whiz
Hi folks
EOS90D from.across the pond. Over the last couple of weeks you guys have helped me move on, and just wanted to say thank you
Two weeks ago all my 7 lenses had uv filters, mainly for protection. Some were stuck!
Now I have got 3 clear glass filters, some CPL filters to eliminate window glare.  I've learnt to use uv filters for protection and take them off to take photographs. I've just taken delivery of an efs 10-22mm wide angle. I've learnt so much about infrared lenses etc.
At the time of writing, I feel that my natural inclination is to be a SOOC photographer, as I'm not a computer guy. It just feels right to me.
So just wanted to thank you guys for your helpful comments and advise. Sure, I'm a few £££ lighter - but its a great hobby and looking forward to my next outing.
Regards
Ramsden
