06-17-2024
10:49 PM
08:01 AM
I currently have a RF 24mm-70mm F2.8 lens for my camera body. I was looking to get a longer lens for some upcoming shoots I have to do. I am on the fence about the 70mm-200mm and the 100mm-500mm, both seem to have pros and cons. I do like having the option for F2.8 on my small lens and thought the same would be a safe option to maintain that sharpness. Any suggestions would be welcomed!
06-18-2024 09:12 PM - edited 06-18-2024 09:14 PM
Nicrkoz1, welcome to the site!
I have the R6 MII, own a 24mm-70mm, a 70mm-200mm and added the 100-500mm. My photography is fairly broad shooting sports, landscape, street and wildlife. Since picking up the 100-500mm my 70-200mm is collecting dust, the two other lenses are always in my pack when I leave the house as well as the 100mm macro.
I find the gap between the 24-70mm and the 100-500mm negligible and so there hasn't been an instance where I was out shooting and wished I had the 70-200mm.
The 100-500mm is a a great lens but has limitations, it will need more light then a 2.8. That being said I recently used it for indoor basketball, pushed the ISO and grabbed some beautiful images but the gym had good lighting. The focus on this lens is fast and my hit rate during the game I would guess was somewhere around 70%. The weight of this lens is so easy to carry all day but that's coming from a guy that carries a Sigma 60-600 which is like carrying a bucket of rocks.
If you want to extend your range you would not go wrong with purchasing the 100-500mm.
That being said, still love the 70-200mm, that used to be my go to lens for basketball.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
06-18-2024 01:09 AM
I own these 3 lenses. I hope these comments will help in your decision process. 😀
The RF 24mm-70mm F2.8 is a true staple and a fantastic everyday lens. I'm sure you have discovered this.
The RF 70-200 f2.8 and RF 100-500 are very different from a purpose standpoint. The current 70-200 is an external zoom compact. The RF 100-500 is also external zoom. You cannot use a TC with the current 70-200. Its possible with the 100-500 above 300mm only. There is a rumor of an RF 70-200 f2.8 Z internal zoom which should (rumored) support a TC for its entire focal range, also the power zoom adapters PZ-E2 and PZ-E2B. There is not an announcement or release date currently. (Just this year).
I really like the compact size of the RF 70-200 "mkI". Its not a focal length I would use with a TC, but we all use our camera's differently. I always say "magic happens" when you put a 70-200 on a Canon body. Its truly one of Canon's best lenses ever. It picks up right where the 24-70 ends and takes breathtaking images.
While having f2.8 is great for low light, bokeh and subject / background isolation, you will not always use this lens wide open. Yes if you have the budget, the choice is always nice. You should consider how you will use the lens primarily. Indoor sports, portraiture, indoor venues / performances, etc. Anywhere when you cannot use a flash. In general, its got you covered. It cannot put kids on the other side of a soccer field or swimming pool near you. It can take great indoor volleyball photos if you are court side.
Until Nov of last year, the RF 100-500 was the only native RF super zoom in a sub <$3K category. Now the RF 200-800 is available at $1900. I'm mentioning it because its possible to purchase. You might have to wait for it a bit, but it does exist. It supports a TC as well, its entire focal range, but you will lose one or more stops of light and a percentage of AF. One thing most here will tell you. If you have a lens with this much reach and you think you need a TC, don't. Instead, try to get closer. Of course there are exceptions.
The RF 100-500 is another lens that offers stunning performance. As with any Canon L series, it offers everything Canon's does best. Fast AF, great IS and is very easy to handle (even hand held). Like the 70-200 it offers superior, razon sharp image quality and reach beyond 200mm.
I feel your "next" lens choice (because there is always one more) 🤣 will depend on what you plan to shoot most. How close will you be to your subjects? What are the lighting conditions likely to be? F2.8 is great for gathering light, but your DOF will be more narrow and if your subject(s) are deep what's in front or in back might not be as sharp wide open. If all you want is a beautiful portrait, and the background to melt away, the 70-200 f2.8 is hard to beat.
If you will have good lighting (plan to shoot mostly outdoors) and need the reach beyond what 200mm can give you the RF 100-500 is equally remarkable. It doesn't offer the same narrow DOF, or melt-away but you will not notice this usually unless the background is directly (right) behind your subject.
Tell us more about the type of photography you do or plan to do with the next lens and others can help further narrow your decision.
06-18-2024 01:27 AM
I currently shoot landscape and wildlife photography. I have a couple shoots later this year where I am following a couple of hunters on their hunt. I just finished up a veteran photography course that involved landscape, wildlife, and photojournalism. I had some moments where the 100-500mm was great to use for photojournalism in the setting I was using it. I feel like with hunting I will be closely working with the subjects. Hope this helps! Also, thank you for the response, that provided a lot of information!
06-18-2024 11:23 AM
"I am on the fence about the 70mm-200mm and the 100mm-500mm, both seem to have pros and cons."
Yes they do and they are not comparable so a choice between the two isn't a good idea. They are designed for totally different situations. You may decide on which to buy first but if the need is there you need both.
Personal Gallery
10-19-2025 05:39 AM
Hi. Can I ask what you went for in the end ?
10-19-2025 05:55 AM
Hi all,
I’m new to proper photography but keen to start taking professional-quality action shots — mainly people on rivers kayaking, sea surfing, rock faces climbing and mountaineering shots plus general outdoor/landscape work. I’ve been looking at the Canon R6 Mark II and it seems popular, so I’m wondering: is that a sensible body to start with for the sort of stuff I want to shoot?
I’d also really appreciate lens recommendations. My thinking (possibly naive) is that I’ll need:
I’m especially interested in lenses that are reasonably well sealed for the outdoors, not ridiculously heavy to carry, and that will let me grow into more professional work with a bit of learning. If any primes are “must-haves” for action or low-light river/rock shots, let me know.
Also — if you think there’s a different camera body that would be better value or a smarter long-term choice for action/outdoor photography, I’d love to hear alternatives and why (pros/cons vs the R6 Mark II).
I don’t have a strict budget right now and am open to both new and used recommendations. Thanks in advance for any advice, suggestions, or example setups — I really appreciate the help!
Pete
10-24-2025 07:44 PM
Hello Pete,
I did a ton of research before choosing the R6 Mark II as the camera I wanted to pair with the RF200-800 for wildlife, including action. I have had the camera for about 15 months now and it is everything I wanted in a camera. It has great low light ability, tremendous autofocus, and excellent image quality, and just lots of capabilities. Now I went for the 200-800 which is not the fastest lens, but most of my shooting is done along the ocean, salt marsh, and longleaf pine savanna. I may not want that lens to shoot in dense forests.
I can't speak for the newer cameras that have come out recently, just this one was right for me. There are many lenses that may work well. You may want to look at some of the lens reviews on you tube, or better yet go on Flickr and look at actual user photos.
One of the things you mentioned is surfing, this combination is superb for surfing.
800mm 1/2000, F10, ISO 160
570mm 1/2500, F8, ISO250
800mm 1/2500, f9, ISO 640
10-25-2025 12:12 AM
Very nice Tom!
