Lens recommendations for capturing stunning portraits
williamjohn5987
Hello,
Which Canon lens do I trust the most for capturing stunning portraits: the fast 50mm f/1.8, the versatile 24-70mm f/2.8, or the powerful 70-200mm f/2.8?
Best Regard,
William
4 REPLIES 4
jrhoffman75
@williamjohn5987 wrote:
Hello,
Best Regard,
William
Any of them will work. "Stunning" results will depend more on your skill.
ebiggs1
As JRH stated "Any of them will work."
The truth and reality is there is no such thing as a portrait lens. All lenses have the exact same perspective if the distance from subject is adjusted accordingly. For an extreme example everybody considers a 24mm lens to be a wide angle good landscapes. However, even a 600mm super telephoto lens is a good wide angle lens if you are shooting a landscape of the Moon. So, you see if distance from subject is adjusted any lens will offer the exact same result.
The so-called portrait lens got is name form studio photographers that were restricted by the room size. To them and most of us in a normal sized studio an 85mm lens did make good portraits for instance. But step outside where distance isn't restricted and perhaps a 200mm lens would work. As a matter of fact a lot of my buds still in the business have gone to the 70-200mm zoom as their 'portrait' lens. I did myself just before I totally retired. One reason studio photography isn't as big of a thing now as it used to be as a lot of portraits are shot on location.
Did you mention what camera you have? If it is a cropper you will need a different FL than if it is a FF model. On a cropper the standard 18-55mm kit lens will do fine. On a FF model the 24-70m might be a tad short but would work. well. And, yes, on a FF the 70-200mm might be king. A tad long at times I found out but useable and quite good.
EOS 1DX and many lenses.
zakslm
Mentor
Mentor
William,
My 2 cents are:
1.  A stunning subject can result in a stunning portrait. Take a look at @lakshaya_click ‘s work in the Gallery section.
2.  Great lighting (and how the subject is lit) makes a great portrait.
3.  About the only lens that usually isn’t suitable for a portrait is an extreme wide angle lens that distorts the  subject’s features (unless that’s the effect your going for).
Hope this helps!
LZ
SignifDigits
I don't see that you posted the camera that you're using.  If you're using an APS-C sensor be sure to factor in the 1.6x crop factor.  Thus, if you're using a cropped sensor camera 70-200mm will be effectively 112-320.  For an APS-C that lens might be a bit long for portraiture if you want to interact with your subject.
I concur with zakslm - lighting and subject are huge, as is the setting.  An excellent book on "how I did this shot", including portraits, is "The Moment it Clicks" by Joe McNally.  He is well-known for work (as in covers of magazines, etc.).  It's available for cheap used and a fun and easy read and full of interesting ideas and his "lessons learned".
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using no Adobe products.
