Reply
Highlighted
Super Contributor
Re: Magic lantern, the Canon 7D firmware 2.0.5?
[ Edited ]
I refer to an earlier post and discussion, I thought mentioning Magic Lantern here is unorthodox :
http://community.usa.canon.com/t5/EOS/How-can-I-get-5-bracketed-exposures-with-my-5D-Mk-II/td-p/1669...
Why nobody is saying anything about it now ?
Highlighted
Reputable Contributor
[ Edited ]
Use Eos Utility to downgrade your firmware or search for downgrade eos 7d at google.
DCS 3c, DCS 520, D30, D60, 1Ds, 300D, 30D, 1000D IR, 7D, 6D, 6D, M5
15-45/3.5-6.3 IS, 16-35/4 IS, 22/2, 24/1.4 II, 24-105/4 IS, 50/1.4, 85/1.8, 100/2.8, 70-200/2.8 IS II, 300/2.8 IS
Highlighted
Super Contributor
BTW, there have been some suggestions (or may be hearsay only) that there are a lot of bad things about ML. What experience do you ML users have about these bad things ?
Highlighted
Super Contributor
Hi Peter, I used both EOS utility (your suggested method)and ML on card to roll back Firmware 1.3.3 to 1.2.3 and 1.1.3 tp my 5D3. Both successful.
No bad things happened. Followed the instruction strictly and you should have no problem.
Highlighted
[ Edited ]
Bad things:
  • Half second slower start because it boots from the card
  • The battery of 7D powerless after removing the memory card wrongly (correct is to wait 2-3 seconds after I have powered off the camera.)
  • In live view and in the ML menu I can only use the ML menu for about 30 seconds before I am kicked out from the menu. This is only for 6D. A known bug.
That are my experience.
Highlighted
Super Contributor
Peter. Thanks for sharing your experience. Yes I agreed ML is not a fully developed thing. Beta versions are coming out to improve and new features are also added. There may be a few not so good things (bad ? to some) but there are some innovative features beyond somebody's imagination.
I have never experience your mentioned problems on my T3i, M, 60D (all sold) It's okay on my 5d3 (X2) and T4i. A few times when I did not operate according to specs, the camera may freeze and I just have to remove the battery and re-insert and it's back to normal. No big deal.
Loading ML is less stressful than updating firmware. But this is just my feeling. I have done this over fifty times (my own experiments and for friends) and all works.
Magic Lantern is not for beginners. Learning your own cameras first. Not all added features will be useful to you. Stick to Canon original and do not install ML even if you have 1% doubt.
powered by Lithium
