Reply
VIP
Re: Canon 5D Mk III firmware update failure
"You have used the camera for years without ever updating the firmware.  Why now?"
I often wonder why people do this when there is no benefit.  If there isn't an issue that is fixed or a lens that doesn't work, other gear, etc, there is no reason to update the FW. You will notice nothing when it is successful.
Honored Contributor
@Waddizzle wrote:
@Foodipedia wrote:
Is there a real difference between update with CF card or SD card? My card is a plain SDHC card. Quite reluctant to format my CF card. I formatted the SD in the camera.
It doesn’t work even with EOS Utility.
I saved the file name with FIR extension. Already downloaded the FIR file again but it still does not work.
If you are certain that the cards are good, that you use them in the camera to save photos, then that is a problem, If it is still not working for you with the EOS Utility, then you should contact Canon Support for assistance.
I'm curious, though.  You have used the camera for years without ever updating the firmware.  Why now?   Is this to correct some issue you are having with the camera?  What is the driving reason to update the camera after so many years?
It is never a good idea to use CF or SD cards as a storage medium. That should be done on a series of hard drives as geographically dispersed as you can manage.
Bob
VIP
???  I do not think anyone is using memory cards for long term storage in this case.
Occasional Contributor
You can say that I am lazy 😅. I just did the FW update with my second camera, a Fuji XE3, that was easy and smooth. So that’s why I wanted to do the same for 5D.
Of course, I use PC for permanent storage. But have no habit of formatting the CF card. Only deleted old photos when the card is out of space.
Just checked with Canon support. They need to charge firmware update fee in addition to inspection fees (as warranty expired long time ago). Perhaps forget the update if there is no significant benefit Smiley Sad
VIP
"... forget the update if there is no significant benefit "
Smart idea! Don't mess with what is already working well.
New Contributor
    I started using my Canon 5D Mark II (purchased in 2007) after several years of non use.  It was working fine and actually bought AC battern adaptor and astrophotography adaptor for it. Current firmware is vers 2.0.9 .  I saw a free firmware update  on the Canon site for ver 2.1.2 but when the camera completed the upload it indicated file read failure.
    The camera is stuck in the firmware update when it is powered on and the firmware update always fails with a file read error. I have downloaded using both the windows 10 pro and macos 10.15.3 versions, used existing  CF cards with pictures which were formated in the camera to save the firmware file, fresh  formated fat32 on CF cards of size 32gb udma 7 delkin and 9gb Lex.
    The camera remains BRICKED  in firmware update dialog on power up.  In this firmware update mode, the camera powers up to load firmware from the CF card even if the power switch is in the off off position.
     You post indicated Canon required you to pay firmware update fee in addition to inspection fee.  Am I being held hostage for the same reason.  I didn't see anythin on the Canon web site stating that the self firmware downloads require you to pay a fee if your warranty has expired?
     Does anyone know how to reset a Canon 5D mark ii  in Firmware Update mode?  Is there one or more buttons that need to be pressed when power is applied or a pressure switch somewhere to force a reset.  I would be happy to go back to vers 2.0.9 .
Esteemed Contributor
Self-downloads are free. However, if you have Canon recover your bricked camera you have to pay the fee.
VIP
The title of the thread says 5D Mk III but your post mentions a Mk II.  Is that what you have a Mk II?  Did you ask Canon if they still service a Mk II?  If they do you need to set up a repair ticket and send it in.  Don't mess with it further.
powered by Lithium
